Brake tubing deburring/chamfer tool recommendations https://ausmini.com/forums/viewtopic.php?f=2&t=100932 |
Author: | Bill B [ Fri Apr 30, 2021 4:36 pm ] |
Post subject: | Brake tubing deburring/chamfer tool recommendations |
Does anyone have a recommendation for a good quality deburring/chamfer tool for 3/16" brake tubing up to, at least, 3/8" for hydro tubing? Have been improvising with files and drill bits but have decided to turn semi-professional! There are some on the internet but the plastic AC/DC ones don't inspire confidence - but willing to be corrected if they work. |
Author: | Harley [ Fri Apr 30, 2021 6:07 pm ] |
Post subject: | Re: Brake tubing deburring/chamfer tool recommendations |
What are you cutting the tube with at the moment? I use a small pipe cutter and the end is quite well cut - usually I only have to go over it with some fine sandpaper to clean it before flaring. |
Author: | Bill B [ Fri Apr 30, 2021 7:05 pm ] |
I am using a Record mini tube cutter. I just wanted the inner and outer edges to be deburred to get a good smooth seal when flared. |
Author: | cgo [ Fri Apr 30, 2021 7:47 pm ] |
I use a mini tube cutter which has a built-in deburring tool for the inner surface. |
Author: | Bill B [ Sat May 01, 2021 10:12 am ] |
cgo wrote: I use a mini tube cutter which has a built-in deburring tool for the inner surface. Thanks, Clive. That is clever. Will look it up. |
