Firewall insulation Mat https://ausmini.com/forums/viewtopic.php?f=2&t=100913 |
Author: | Firefirey [ Thu Apr 22, 2021 7:02 pm ] |
Post subject: | Firewall insulation Mat |
Had a go at making an original looking firewall mat for the cooper s |
Author: | iansmini67 [ Thu Apr 22, 2021 7:07 pm ] |
Post subject: | Re: Firewall insulation Mat |
Please do tell more. I'd like to know the how and what. Sent from my SM-G986B using Tapatalk |
Author: | Firefirey [ Thu Apr 22, 2021 7:50 pm ] |
I managed to find the jute underlay and vinyl from a supplier in Australia. The vinyl is used as a tornou cover on utes as I understand it. I had the original firewall insulation mat from the car but it was in bad shape and not complete. If you do a search on the forum under the title you will find a lot of information regards the two types of mats used and the grains of the vinyl and the colour which is almost a charcoal colour. Forum members sent me some photo's of the complete firewall mat which helped to complete the correct shape. I made a cardboard patten first and fitted it to find the correct locations of the cuts and then took the measurements from my old mat and came up with a nicely fitting end result. You will need to make your judgment on colour and patten but when I put old with new side by side I'm very happy. |
Author: | simon k [ Thu Apr 22, 2021 9:04 pm ] |
that's beautiful, well done! |
Author: | Bill B [ Fri Apr 23, 2021 10:20 am ] |
Sets off a very neat engine bay. |
Author: | Firefirey [ Sat Apr 24, 2021 4:38 am ] |
Thanks Simon K and Bill B. Iansmini67. I hope some of the information was of help. |
Author: | fffffred [ Wed May 12, 2021 7:30 pm ] |
@Firefirey, do you mind sharing the supplier details? Looks awesome. Thanks |
Author: | iansmini67 [ Wed May 12, 2021 7:38 pm ] |
Yes, Very helpful and really does look amazing. I'm with fffffred, I'd ben keen to know the suppliers please. |
Author: | phillb [ Thu May 13, 2021 7:41 am ] |
Looks good. I had also been told a while back that the vinyl was the same as Ute cover. The cut for the windscreen bottle, is that a long vertical slit almost to the bottom then a small horizontal slit? Does it fit around and over the bracket? Sent from my iPhone using Tapatalk |
Author: | Firefirey [ Sun May 16, 2021 7:14 pm ] |
phillb wrote: Looks good. I had also been told a while back that the vinyl was the same as Ute cover. The cut for the windscreen bottle, is that a long vertical slit almost to the bottom then a small horizontal slit? Does it fit around and over the bracket? Sent from my iPhone using Tapatalk Hi Phil My understanding is that the washer bottle bracket was screwed to the firewall and the insulation mat had the long cut - top to almost bottom with a small t - cut at the bottom which allowed the insulation mat to fit around the bracket and the washer bottle which makes a neat finish to the fitment of the insulation mat |
Author: | phillb [ Tue May 18, 2021 5:15 pm ] |
Firefirey wrote: phillb wrote: Looks good. I had also been told a while back that the vinyl was the same as Ute cover. The cut for the windscreen bottle, is that a long vertical slit almost to the bottom then a small horizontal slit? Does it fit around and over the bracket? Sent from my iPhone using Tapatalk Hi Phil My understanding is that the washer bottle bracket was screwed to the firewall and the insulation mat had the long cut - top to almost bottom with a small t - cut at the bottom which allowed the insulation mat to fit around the bracket and the washer bottle which makes a neat finish to the fitment of the insulation mat Sent from my iPhone using Tapatalk |
