Single use CV washers? https://ausmini.com/forums/viewtopic.php?f=2&t=100877 |
Author: | timmy201 [ Mon Apr 05, 2021 3:27 pm ] |
Post subject: | Single use CV washers? |
I thought new washers would be a good option as the old ones had a step in them. One side fell to pieces when I removed it, I checked the other side and it’s a similar story. Check out all the cracks ![]() |
Author: | DavidE [ Mon Apr 05, 2021 5:19 pm ] |
Post subject: | Re: Single use CV washers? |
timmy201 wrote: I thought new washers would be a good option as the old ones had a step in them. One side fell to pieces when I removed it, I checked the other side and it’s a similar story. Check out all the cracks ![]() Yep. Standard quality. |
Author: | mickmini [ Tue Apr 06, 2021 10:14 am ] |
Wow. Not at all tempered properly. Might be better to grind the originals flat again? |
Author: | GR [ Wed Apr 07, 2021 5:59 pm ] |
Hi Tim That is a problem with these washers. they are just to brittle I made some out of chrome molly with no slot in them. They work really well the factory rally cars used them in the 60's, there was a guy in Victoria making some not sure of his name a lot of the NB race cars are running them and we have them in road cars because of the problem you are having. Graham Russell Sorry Tim I forgot to say Swiftune sell a good quality washer that work well. |
Author: | Karcraft [ Wed Apr 07, 2021 10:19 pm ] |
Karcraft are aware of this problem that has just started to occur. We have sourced a steel FAM9270 which shd be into store within the week. We will advise the OE manufacturer in the UK about problems we are having with the standard washers. |
Author: | DavidE [ Thu Apr 08, 2021 6:07 am ] |
Karcraft wrote: Karcraft are aware of this problem that has just started to occur. We have sourced a steel FAM9270 which shd be into store within the week. We will advise the OE manufacturer in the UK about problems we are having with the standard washers. Actually I had this problem 3 years ago. |
Author: | 9YaTaH [ Thu Apr 08, 2021 7:58 am ] |
Karcraft wrote: Karcraft are aware of this problem that has just started to occur. We have sourced a steel FAM9270 which shd be into store within the week. We will advise the OE manufacturer in the UK about problems we are having with the standard washers. Good to hear - Thank You for the feedback ![]() |
Author: | Stuwey [ Thu Apr 08, 2021 8:46 am ] |
GR wrote: I made some out of chrome molly with no slot in them.. KAD also do full-circle ones without the split. |
Author: | minimanic [ Thu Apr 08, 2021 3:07 pm ] |
We stock the solid ones at Minis Plus (03) 9729 1323. These are the Australian made ones. Top quality part that's been extensively Street and Track tested. We get them directly from the manufacturer. https://www.minisplus.com.au/classic-mi ... e-cooper-s |
Author: | timmy201 [ Fri Apr 09, 2021 1:17 pm ] |
An update for those interested: Monday (public holiday) - noticed the broken washers Tuesday - contacted the supplier (the always helpful Karcraft) with a photo of the broken item and asked if they had any higher spec items in stock. They said some would be coming in during the next week. Thursday - shipment came in and they’re sending out some of the new steel ones As usual, perfect service from the Karcraft team. |
Author: | winabbey [ Fri Apr 09, 2021 2:03 pm ] |
timmy201 wrote: Thursday - shipment came in and they’re sending out some of the new steel ones As usual, perfect service from the Karcraft team. Good outcome and response from Karcraft. Since this doesn't appear to be a one-off but instead a batch or brand of an inferior part I hope Karcraft will be contacting all those customers who purchased the original poor part and offering a replacement like they have done for you. Unless I'm missing something this should be no different to the non-automotive product recalls we see regularly. You would expect Karcraft to also make a claim on the supplier of the faulty washer. |
