https://ausmini.com/forums/
Core Plug Sealer
https://ausmini.com/forums/viewtopic.php?f=2&t=100807
Author:  AJ [ Thu Mar 04, 2021 12:35 pm ]
Post subject:  Core Plug Sealer
What is a good sealer for core plugs
Author:  drmini in aust [ Thu Mar 04, 2021 1:39 pm ]
Post subject:  Re: Core Plug Sealer
Stag is best. However I've used Loctite 515 or Permatex aviation gasket cement successfully.
Author:  Stibbsy [ Thu Mar 04, 2021 2:03 pm ]
Doc, I was told stag is vey susceptible to the modern coolants we use these days. I have used loctite 515 with success.
Author:  TK [ Thu Mar 04, 2021 4:02 pm ]
stag
Author:  Bill B [ Fri Mar 05, 2021 4:05 pm ]
I used Stag on a leaking plug about 3 years ago and it's still holding OK, with corrosion inhibitor in coolant.
Author:  AJ [ Wed Mar 10, 2021 12:01 pm ]
Ok thanks for the info :D
Author:  Harley [ Thu Mar 11, 2021 5:05 pm ]
I put Stag on the core plugs in an engine I did 10 years ago - still not leaking!
Everything else in the mini however....
Author:  mickmini [ Sat Mar 13, 2021 12:01 pm ]
I used a dab of the mercury non hardening gasket sealer on mine about 14 years ago. No leaks!
Author:  Scoop [ Sat Mar 20, 2021 8:08 am ]
Aviation sealer or Wurth pipe seal. Never had any issues with either.
