It is currently Sun Jun 29, 2025 8:34 am
 Post subject: Battery Label
PostPosted: Wed Mar 17, 2021 6:09 am
who supplied the original battery for the mini's in Australia when they left the factory in the 1960 - 1970 year's
Has any one got a photo of the battery label :)
 Post subject: Re: Battery Label
PostPosted: Wed Mar 17, 2021 2:38 pm
I can't remember which brand of battery was in my mini K in 1969 but do remember it was a 3/4 sized battery that needed a metal spacer piece to pack out the battery so the retaining clamps could work properly. The box itself was big enough to take a normal-sized battery when time came for a replacement.
Tyres were Olympic 'Air Ride' cross plies and there was an Olympic Rubber factory next door to BMC at Zetland, so they may have supplied batteries too.
But like paint brands, BMC may have sourced from several companies.
PostPosted: Wed Mar 17, 2021 4:26 pm
The Mk1 range had a full size Lucas battery. The MK2 range went to a smaller battery with spacer. The brochures say it was a 40 amp/hr @ 20hr rate but no mention of model or part number.
Sometimes there was a battery check/receipt and this was placed into the passport to service. I will go through my photos and see if I can find a part number.
Maybe someone can check their parts book and see if it lists a make and part number.
PostPosted: Wed Mar 17, 2021 5:35 pm
The parts books don't mention the battery or tyres by part number.
PostPosted: Wed Mar 17, 2021 8:19 pm
Apparently the worhshop manual lists a few Lucas models - viewtopic.php?f=2&t=96188
PostPosted: Thu Mar 18, 2021 6:42 am
Hi Brad
Thanks for your help and past post reference to my question and if you do find a photo that would be even better :D
Also thank you to everybody else for their reply.
Pete
