It is currently Sun Jun 29, 2025 11:32 am
PostPosted: Thu Mar 04, 2021 7:23 am
What is the general consensus on fitting these? Mine has never had one in my ownership and I was wondering if it is worthwhile or not?
I'm not overly bothered about the originality view - my Mini is not a show car or even remotely original. My question is more about any cooling performance benefit.
https://minisport.com.au/mini-moke-radi ... d-together
Cheers, Paul.
1970 Morris Mini K
PostPosted: Thu Mar 04, 2021 7:30 am
Waste of time. Except for originality.
I've not used one for 30+ years.
Later UK cars didn't even have the shroud up against the radiator.
Edit I meant body cowl not shroud.
Last edited by drmini in aust on Thu Mar 04, 2021 1:37 pm, edited 1 time in total.
PostPosted: Thu Mar 04, 2021 8:07 am
Thanks Doc.
1970 Morris Mini K
PostPosted: Thu Mar 04, 2021 10:10 am
When you say the latter UK cars didn’t have the shroud up against the rad, do you mean the two pieces that are detachable on the engine side of the rad or the outer fixed body side?
Si.
Clubman GT April 1972 - YG2S8 - 1140
PostPosted: Thu Mar 04, 2021 1:36 pm
Fixed body side.
PostPosted: Thu Mar 04, 2021 2:08 pm
One reason they were removed is that it caused undue wear to the top radiator tank.
PostPosted: Thu Mar 04, 2021 5:48 pm
Thanks for clarifying for me guys.
Si..
PostPosted: Thu Mar 04, 2021 8:35 pm
They do too!
Polishes right through the paint and into the brass!
PostPosted: Fri Mar 05, 2021 12:10 pm
And how would it do that when its not supposed to even touch the radiator??
Maybe revise your fitting technique. The gap is what the rubber seal is intended to bridge.....
Cheers,Ian
PostPosted: Fri Mar 05, 2021 9:59 pm
The strap is wider than the gap it fills, the retaining clips hold it hard up to the radiator.
