It is currently Sun Jun 29, 2025 12:34 am
PostPosted: Sun Mar 07, 2021 12:42 pm
I have just bought a new Mk2 flare set. They are black plastic. I was wondering what prep work is required before painting the body colour. They have not been fitted yet.
PostPosted: Sun Mar 07, 2021 6:49 pm
I cleaned mine with oil and grease remover, then sprayed with plastic primer, then colour coat. Been perfect for the last 5 years on the car.....
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun Mar 07, 2021 7:26 pm
I have painted a multiple sets over the past few years, using acrylic paint. I follow a locked thread HowTo by Phat Kat. A very helpful guide to car painting.
http://www.ausmini.com/forums/viewtopic.php?f=25&t=63720
As the flares are not required to flex I treat them like a metal body part and have had no issues. I have painted non-Mini plastic bumpers and have added a flex aid due to the pliable nature of the bumpers, the paint shop where I buy paint gave this advice.
As new flares come in good condition, I initially scuff them with a very fine sanding sponge, then basically follow Phat Kat's HowTo. I dry sand where I can and use foam backed sanding sponges where possible. I haven't used guide coat lately, but have used a product by Bodyworx - Imperfection Sanding Guide.
If you are using 2K paint, you'd have to modify some steps. If this is the case, hopefully an expert can provide some guidance.
Good luck.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Sun Mar 07, 2021 8:27 pm
When I got mine, I spoke to a cousin who was a spray painter amd he suggested degreasing then scrub with scotchbrite pad then plastic primer, colour and clear coat. Mine have been fine for years.
Cheers Dave.
PostPosted: Sun Mar 07, 2021 11:23 pm
Trial fit first, to check if they need any cleanup where they sit over the seams mouldings.
PostPosted: Mon Mar 08, 2021 11:18 am
As cgo said - treat them like a metal part as they don't flex I have never bothered with plastic primer. Light scuff with Scotchbrite or P400 wet/dry. Then primer - flatten - topcoats as normal.
The flares are more likely to stress crack around the seam mounding cut-outs and the cut-outs for hooking them over the trim buttons, that you don't need to fit anyway.
PostPosted: Mon Mar 08, 2021 1:33 pm
Bill B wrote:
... and the cut-outs for hooking them over the trim buttons.
Those cutouts are not made in current flare manufacture since no-one uses them.
PostPosted: Tue Mar 09, 2021 2:50 pm
That is a definite improvement! But there will be many earlier or original flares with the cutouts.
I have had to reinforce almost every cutout with fibreglass before repainting them.
Users browsing this forum: 748rum and 82 guests
