https://ausmini.com/forums/
1098 crankshaft identification
https://ausmini.com/forums/viewtopic.php?f=2&t=100799
Author:  simon k [ Sun Feb 28, 2021 11:10 am ]
Post subject:  1098 crankshaft identification
Does anyone know casting numbers or other identifiers to tell if a crank is a 1098. Going to look at a job lot of parts, trying to find a 1098 crank..
Thanks
Author:  timmy201 [ Sun Feb 28, 2021 11:28 am ]
Post subject:  Re: 1098 crankshaft identification
12G82
Author:  simon k [ Sun Feb 28, 2021 11:44 am ]
Thanks, fingers crossed
Author:  simon k [ Sun Feb 28, 2021 12:43 pm ]
Was it the same for all 1098, ie from Morris 1100 to clubman?
Author:  timmy201 [ Sun Feb 28, 2021 12:52 pm ]
I believe it was the only part number for 1100 cranks.
Author:  drmini in aust [ Sun Feb 28, 2021 4:43 pm ]
Crack test it before you part with $$$.
They are much more likely to crack than 998 ones.
They need a good fillet radius to survive, sadly some crank grinders don't know or don't care.
I've thrown 2 over the years because of this.
Last one had been reground -0.010" undersize and was hardly worn.
Author:  GR [ Sun Feb 28, 2021 7:08 pm ]
HI Simon
You will find that most 1100 cranks have yellow paint on them, and not all of them have a cut out on the two centre counter weights where they drill down through the centre main to number 2 and 3 pins for the oil way.
Graham Russell
Author:  simon k [ Sun Feb 28, 2021 9:00 pm ]
We found one, no chance of crack testing it though - it was still in a block and had probably never been out of it since new... grabbed that and a couple of rod change boxes.
You may see it in your workshop in the near future GR ;)
Author:  9YaTaH [ Mon Mar 01, 2021 7:49 am ]
Was Sime in Bowral on Sunday :?: :arrow:
Author:  TK [ Wed Mar 03, 2021 1:18 pm ]
or 12G2827. I have a few left
Author:  timmy201 [ Wed Mar 03, 2021 1:42 pm ]
They’re the special ones :D . Big bore 1100!
