Automatic gearbox priming https://ausmini.com/forums/viewtopic.php?f=2&t=100777 |
Author: | simonw [ Thu Feb 18, 2021 9:25 am ] |
Post subject: | Automatic gearbox priming |
Anybody had to prime an auto box through a priming port on the governor housing? I cant get drive on a freshly built box... so just trouble shooting. The fresh 1293cc on top of it is running like a dream sowing machine though ![]() Sent from my iPad using Tapatalk |
Author: | drmini in aust [ Thu Feb 18, 2021 2:16 pm ] |
Post subject: | Re: Automatic gearbox priming |
Usually it's because the pipe seal has been displaced when fitting the forward clutch back in. I've done two of these and never had to prime the box. |
Author: | simonw [ Fri Feb 19, 2021 8:00 am ] |
Thanks doc. That’s my fear .... forward clutch out again . Wonder if it can be done in car... Sent from my iPad using Tapatalk |
Author: | drmini in aust [ Fri Feb 19, 2021 3:45 pm ] |
No room. After doing it I would test run it on the floor, just long enough to test pressures at the plug on the filter housing in reverse and forward gears. |
