It is currently Mon Jun 30, 2025 12:35 pm
PostPosted: Thu Feb 18, 2021 9:25 am
Anybody had to prime an auto box through a priming port on the governor housing?
I cant get drive on a freshly built box... so just trouble shooting.
The fresh 1293cc on top of it is running like a dream sowing machine though :)
Simonw
Brisbane QLD
1st car - 1964 Mini Panelvan 850
Previous - 1978 Leyland LS 1275 Gold
- 1969 Mini K
PostPosted: Thu Feb 18, 2021 2:16 pm
Usually it's because the pipe seal has been displaced when fitting the forward clutch back in.
I've done two of these and never had to prime the box.
PostPosted: Fri Feb 19, 2021 8:00 am
Thanks doc. That’s my fear .... forward clutch out again .
Wonder if it can be done in car...
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Fri Feb 19, 2021 3:45 pm
No room.
After doing it I would test run it on the floor, just long enough to test pressures at the plug on the filter housing in reverse and forward gears.
