It is currently Mon Jun 30, 2025 6:19 pm
PostPosted: Sat Feb 13, 2021 9:12 pm
I fitted new ball joints 2 years ago and I have now found one top ball joint has excessive movement. .I had noticed a rattle noise and that is why I checked the suspension. Problem is when I take the 3 shims out there is still wear and movement in the ball joint. Cant figure out why? I will replace the ball joint next week, Has anyone had this problem ? When I fitted the new ones 2 years ago they were perfect and I torqued them up to the specs .
Allen
PostPosted: Sun Feb 14, 2021 5:03 am
Back when we could get Leyland or Rover or Unipart ball joints they were a quality product. These days it depends where made, some out there are of dubious quality. There have been cases of them breaking in service... It's a worry.
PostPosted: Sun Feb 14, 2021 8:19 am
Thanks doc I bought them from mini kingdom so I expected they would be ok
Your help and knowledge is always appreciated.
Allen
PostPosted: Sun Feb 14, 2021 1:52 pm
I have a spare 8G4197EVA MG Rover kit if that helps.
PostPosted: Sun Feb 14, 2021 2:13 pm
"I bought them from mini kingdom so I expected they would be ok" and that's what he said too
PostPosted: Sun Feb 14, 2021 9:28 pm
Some faces of the ball and cup are not entirely symmetrical, so when you had a 'tight' joint upon initial assembly, this could have been due to both faces of each having high spots.
One mod I have done - new or old - is to lapp the surfaces with some grinding paste. Put the cup and the ball together in their mated position, and insert the threaded section of the ball in drill, whilst the cup is held in a vice.
You'll more often than not find that this then requires the removal of shim/s - only due to the inconsistency of the 'roundness' of both surfaces.
PostPosted: Mon Feb 15, 2021 7:53 am
There was a discussion about the Japanese made ball joints here viewtopic.php?f=2&t=99955&p=1055472&hilit=Classicminisjapan#p1055472 not sure if @TK reported back. If they are built to Japanese spec in Japan then you would expect them to be a quality product
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
PostPosted: Mon Feb 15, 2021 9:19 am
Re the removing of shims..
Many new ones only have room for 1 shim in, a few times I have had to machine the face of the cap to make room!
PostPosted: Mon Feb 15, 2021 5:08 pm
Thanks boys for all the great information .
Allen
Users browsing this forum: No registered users and 72 guests
