It is currently Mon Jun 30, 2025 6:19 pm
 Post subject: Camber
PostPosted: Mon Feb 08, 2021 8:00 am
While I have been messing with tyres and wheels I noticed the driver side wheel is at an odd angle. visibly way too much camber. quick measurement shows 2.8 deg neg.
I have adjustable arms and I set it at 1.2 deg both sides a couple of years back.
I cannot see any obvious faults and ride height is where I set it so I adjusted camber back to original.
What would cause camber to change like this?
Cheers Dave.
 Post subject: Re: Camber
PostPosted: Mon Feb 08, 2021 9:18 am
Shot lower control arm bushes.
PostPosted: Mon Feb 08, 2021 9:59 am
Speed + air + heavy landing = more neg camber :lol:
PostPosted: Mon Feb 08, 2021 10:23 am
Polyurethane bottom arm bushes that have taken a set?
PostPosted: Mon Feb 08, 2021 3:40 pm
Thanks guys will check and report. Wheel has to come off again anyway.
Cheers Dave.
PostPosted: Sun Feb 14, 2021 11:56 am
it will vary if you roll the car backwards then measure. always roll forward to let it set then measure.
