It is currently Sun Jun 29, 2025 10:09 am
 Post subject: Fuel level sensor
PostPosted: Thu Feb 11, 2021 1:12 pm
Hi all,
I have just tested the two sensors I have to see which one I should use in my 66 Mk1 Cooper S with the voltage regulator., The resistance readings were inconsistent. By wriggling the float arm the resistance would come and go.
I opened them up and adjusted the tension on the wiper arm. Now I get the maximum and minimum values, and other resistance values across the operating range, mentioned in another post.
There isn't any obvious sealer or gasket, by opening them up have I potentially allowed fuel to fill the box containing the resistor?
Are they supposed to run wet, or dry?
After all the time and money invested I really don't want a fire or tank explosion, especially if my insurance company considers my actions contributed to the fire.
Thanks in advance Stewart
Mk 1 Cooper S 1965
If you could erase all your mistakes of the past
You would also erase the wisdom of your present
Remember the lesson not the disappointment.
 Post subject: Re: Fuel level sensor
PostPosted: Thu Feb 11, 2021 8:40 pm
hi all, I found this on the UK mini forum it looks like it answers my question.
I hope the link works. Rgds Stewart
https://www.theminiforum.co.uk/forums/t ... uge-sender
Mk 1 Cooper S 1965
Users browsing this forum: No registered users and 120 guests
