It is currently Tue Jul 01, 2025 11:00 pm
 Post subject: Parts ID
PostPosted: Thu Jan 28, 2021 3:23 pm
Hi guys, trying to id som parts i got in a job lot. Looks like a couple of clutch bearings? But all the black seals are beyond me. The three big bits I'm not sure are mini at all... Any help is great. ImageImage
Sent from my SM-A515F using Tapatalk
 Post subject: Re: Parts ID
PostPosted: Thu Jan 28, 2021 3:34 pm
One looks like a water pump seal.
PostPosted: Thu Jan 28, 2021 3:40 pm
Couple of clutch throwout bearings, couple of brake/clutch master or slave seals, a wheel bearing seal????
Cheers, Ian
PostPosted: Thu Jan 28, 2021 4:54 pm
Ooh is one a diff output seal?
PostPosted: Thu Jan 28, 2021 5:04 pm
timing cover ?
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
PostPosted: Sat Feb 06, 2021 8:03 pm
Flat metal bit with 3 slots is of the clutch diaphragm, throw out bearing runs on it.
Metal bit with 5 lugs is a lock tab for front wheel bearings of a Landcruiser or similar.
Long flat metal thing with markings, 6 inch metal rule!!!
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
Users browsing this forum: simsy98 and 111 guests
