Su fuel leak help required https://ausmini.com/forums/viewtopic.php?f=2&t=100728 |
Author: | Tomtax [ Sun Jan 31, 2021 1:13 pm ] |
Post subject: | Su fuel leak help required |
Hi all My mini k is leaking fuel. It seems that a spiral looking pipe from the bowl to the base of the carbie has come apart How do you fix this? Thanks in advance |
Author: | drmini in aust [ Sun Jan 31, 2021 1:32 pm ] |
Post subject: | Re: Su fuel leak help required |
It's part of the main jet. Buy a new one and that hose is included. |
Author: | Tomtax [ Sun Jan 31, 2021 1:40 pm ] |
Thanks doc Is it just a case of ordering a 11/4 jet? Are there many variants Thanks |
Author: | drmini in aust [ Sun Jan 31, 2021 3:44 pm ] |
P/no TK6000 jet 0.090" For HS2 and HS4 SU. From Karcraft catalogue. |
Author: | winabbey [ Sun Jan 31, 2021 3:58 pm ] |
drmini in aust wrote: P/no TK6000 jet 0.090" For HS2 and HS4 SU. From Karcraft catalogue. This what it looks like - https://minisport.com.au/mini-moke-su-main-jet-090-type |
Author: | Tomtax [ Sun Jan 31, 2021 8:12 pm ] |
Legend Doc |
Author: | Bill B [ Mon Feb 01, 2021 7:24 pm ] |
There are a few details that need to be observed when fitting a new jet between the carby and float bowl - especially where the plastic tube is connected to the bottom of the float bowl. Look at a workshop manual to see where the plastic tube is sealed by the O ring at the fuel bowl. This is a common site of fuel leaks. Sometimes, you are lucky and the leak just needs the 1/4AF nut to be tightened very lightly. |
