It is currently Mon Jun 30, 2025 12:16 pm
PostPosted: Sat Jan 30, 2021 11:28 am
As the title says, which is best, the one with a hole in the side or the one without the side hole.
PostPosted: Sat Jan 30, 2021 11:34 am
Online
I think the best ones these days are the ones with the correct hardness and radius ground into the tappet surface.
PostPosted: Sat Jan 30, 2021 12:09 pm
This may help - https://russellengineering.com.au/camshaft-followers/
PostPosted: Sat Jan 30, 2021 8:13 pm
Safest bet is second hand BMC ones, spherically ground by Graham Russell in Sydney or Matt Read in Brisbane.
Nitriding the reground cam helps life too.
Last time I spoke with Graham 2 weeks ago about the Kent lifters, he gave them his blessing, maybe the info in his blog above may be out of date now?
Moral of lifters story- don't bin your old ones unless chipped on the face. Get them reground.
PostPosted: Sun Jan 31, 2021 6:41 am
Oh dear, worry, worry...
Hi All
At the moment the only cam followers I would put in a motor with out grinding are the Kent Cams CF95, these
followers are all around 63 RC very hard and have the correct radius on them I haven't seen mini followers that hard for 30 years or more.
These followers are not cheap 95 pounds a set, they claim they are made in the UK but you only get what you pay for.
Graham Russell
PostPosted: Sun Jan 31, 2021 8:57 am
Who does spherical cam followers grinding in Newcastle and what is the cost.
PostPosted: Sun Jan 31, 2021 9:29 am
PM sent.
PostPosted: Wed Feb 03, 2021 9:19 pm
Tighe Cams in Brisbane resurface followers.
