Rocker cover breather barb fitting https://ausmini.com/forums/viewtopic.php?f=2&t=100720 |
Author: | timmy201 [ Fri Jan 29, 2021 10:17 am ] |
Post subject: | Rocker cover breather barb fitting |
Hi all, Hopefully someone can help me with this one as it’s been difficult to track down what I need: Rocker cover thread is 1/2” UNF 20 (or a very close tapered thread) I want a 90 degree fitting that’ll thread in and have a 1/2” breather outlet I can’t seem to find any brass 90 degree fittings that are the right thread or outlet size My second option is a banjo bolt, but I haven’t found any barb fittings in 1/2” outlet with the right size inner diameter Thanks! |
Author: | Gambo [ Fri Jan 29, 2021 11:29 am ] |
Post subject: | Re: Rocker cover breather barb fitting |
Hey Tim Autobarn at Albion Park have a heap of different fittings - I needed some 3/8 NPT stuff for my fuel reg. Took it in with me to make sure I got the right size/thread etc. May be worth a shot,they might have what you need behind the counter. Sent from my iPhone using Tapatalk |
Author: | TDS76 [ Fri Jan 29, 2021 1:05 pm ] |
If it is a tapered thread are you sure it is UNF? It may be BSP (British Standard Pipe) which are still commonly used today - a plumbing supplier may be better. A 1/4" pipe thread is the following: OD 0.518", 19 TPI. Cheers, Paul. |
Author: | timmy201 [ Fri Jan 29, 2021 1:22 pm ] |
TDS76 wrote: If it is a tapered thread are you sure it is UNF? It may be BSP (British Standard Pipe) which are still commonly used today - a plumbing supplier may be better. A 1/4" pipe thread is the following: OD 0.518", 19 TPI. Cheers, Paul. Thanks Paul, I had the crazy idea that 1/4 BSP would have been a 1/4” OD thread but obviously that isn’t the case now I’ve read up some more! Looks like there is a good choice in 1/4 BSP to 1/2” barb so I’ll have to check the local shop |
Author: | Steam [ Fri Jan 29, 2021 3:18 pm ] |
Even if you can find a right angle barb of close size threadwise, then run that threads tap into the offending thread and use some thread sealant or ptfe tape. But it sounds like a 1/4 bsp to me. |
Author: | timmy201 [ Sat Jan 30, 2021 3:55 pm ] |
Autobarn Albion Park found me an elbow with the right thread and hose size (TFI #BME1214) which matches the thread on the old straight fitting. Thanks for sorting me out Paul & Gambo It’s about 1cm too long on the barb end, so it’ll need to meet the grinder |
Author: | Gambo [ Sat Jan 30, 2021 5:01 pm ] |
Good to hear Tim - they are my local weekend go to for things like that now. Sent from my iPhone using Tapatalk |
