Parts ID https://ausmini.com/forums/viewtopic.php?f=2&t=100718 |
Author: | bluehishouse [ Thu Jan 28, 2021 3:23 pm ] |
Post subject: | Parts ID |
Hi guys, trying to id som parts i got in a job lot. Looks like a couple of clutch bearings? But all the black seals are beyond me. The three big bits I'm not sure are mini at all... Any help is great. ![]() ![]() Sent from my SM-A515F using Tapatalk |
Author: | cooperess [ Thu Jan 28, 2021 3:34 pm ] |
Post subject: | Re: Parts ID |
One looks like a water pump seal. |
Author: | 1071 S [ Thu Jan 28, 2021 3:40 pm ] |
Couple of clutch throwout bearings, couple of brake/clutch master or slave seals, a wheel bearing seal???? Cheers, Ian |
Author: | bluehishouse [ Thu Jan 28, 2021 4:54 pm ] |
Ooh is one a diff output seal? Sent from my SM-A515F using Tapatalk |
Author: | Andosoft [ Thu Jan 28, 2021 5:04 pm ] |
timing cover ? |
Author: | Scoop [ Sat Feb 06, 2021 8:03 pm ] |
Flat metal bit with 3 slots is of the clutch diaphragm, throw out bearing runs on it. Metal bit with 5 lugs is a lock tab for front wheel bearings of a Landcruiser or similar. Long flat metal thing with markings, 6 inch metal rule!!! |
