info please mini auto https://ausmini.com/forums/viewtopic.php?f=2&t=100711 |
Author: | p7676 [ Fri Jan 22, 2021 6:58 pm ] |
Post subject: | info please mini auto |
Hello ,My friend has a morris 1300 auto he has fitted a screw on oil filter, it keeps on blowing the seal on the oil filter ,the engine oil is also the transmission oil. He has been informed that he will have to go back and fit the bolt on type oil filter because of the high pressure. Is this the same in a mini auto ? Allen |
Author: | simon k [ Fri Jan 22, 2021 8:34 pm ] |
Post subject: | Re: info please mini auto |
it should be the same for the mini auto.. they're the same transmission. They normally have a large filter mounted horizontally Google says that the oil pressure runs up to 142-158psi (reverse). I'm sure that'd be more than a spin on oil filter would be rated to handle |
Author: | drmini in aust [ Sat Jan 23, 2021 4:41 am ] |
These boxes run up to 150 psi. No spin on filter will stand this. Fit an original cartridge filter. There was a thread here I think, Morris1100 had some input, it also came up on American forums. The relief valve on the motor only controls the pressure in the block not the gearbox. There is a pressure test plug on the filter housing. (Edit) on the top of the gearbox. We owned a 1300 auto for 5 years or so. Morris 1300 auto has a short fat cartridge filter to clear its engine mount bracket. Mini auto has a smaller but longer one. Otherwise much the same box. It would blow up spin on filters too. |
Author: | p7676 [ Sat Jan 23, 2021 9:12 am ] |
Great info thanks Allen |
Author: | drmini in aust [ Sun Jan 24, 2021 8:45 am ] |
I wonder who is selling these spin on adaptors, they are obviously inadequate for a BMC 998/1098/1275 auto box.... That's 2 M1300 autos I've heard of with this problem in the past week. |
Author: | simonw [ Tue Jan 26, 2021 12:48 pm ] |
Expensive oil to be losing as well Sent from my iPad using Tapatalk |
