It is currently Thu Aug 21, 2025 11:51 am
 Post subject: Rod change housing bush
PostPosted: Mon Dec 21, 2020 7:40 pm
Below is a photo of the front bush in the rod change gear lever housing.
As can be seen it as almost warn through the bush into the alloy housing.
Can these be replaced and what with.
PostPosted: Tue Dec 22, 2020 6:15 am
I have sourced these bushes from bearing suppliers.
PostPosted: Wed Dec 23, 2020 6:29 am
I have also machined a new brass bush and pressed it in with loctite, worked well.
PostPosted: Wed Dec 23, 2020 7:14 am
Phil drop it in to me, if I can't buy a bush I will machine one up. And fit it.
PostPosted: Wed Jan 13, 2021 8:45 pm
Picked up some bushes from CBC Bearings in Penrith today and pressed one into the housing. :D
Here’s the details if anyone needs one in the future.
Users browsing this forum: Bing [Bot], timmy201 and 97 guests
