Wheel hub to wheel arch distance (wheel width and offset) https://ausmini.com/forums/viewtopic.php?f=2&t=100656 |
Author: | Bubbacluby [ Fri Jan 01, 2021 6:03 pm ] |
Post subject: | Wheel hub to wheel arch distance (wheel width and offset) |
Does anyone know what the factory distance is between the wheel mounting hub (Where the wheel bolts on) to the wheel arch for a disc brake car. Trying to work out how much overhang a particular set of wheels will have past the wheel arch for determining arch size. (I know width and offet). Thanks |
Author: | Steam [ Sat Jan 02, 2021 6:57 am ] |
Post subject: | Re: Wheel hub to wheel arch distance (wheel width and offset |
The front wheel track should be 1205mm originally. you should be able to work it out from that. |
Author: | Bubbacluby [ Wed Jan 06, 2021 7:19 pm ] |
Steam wrote: The front wheel track should be 1205mm originally. you should be able to work it out from that. Thankyou |
