It is currently Sat Aug 23, 2025 7:02 am
PostPosted: Sat Dec 26, 2020 9:10 am
Stupid question I know I should be going to the auto-electrician!!
I’ve purchased the 17ACR - 45 Amp Alternator as advertised on Minisport in Adeliade. But no wiring diagram so before I burn my mini to the ground can any please confirm?
Is the bolt on top the Earth?
And is the top sliver lug what was marked as IND on the original Lucas Alternator?
Guessing the two larger copper terminals are AUX?
[img]
[/img]
PostPosted: Sat Dec 26, 2020 9:29 am
From memory the small silver lucar terminal is ind.
The two copper large termi als are both power and go to the solenoid main battery terminal. I ran an extra cable to give more power capacity.
The alternator earths throuvh the mounting bolts.
I will go out and check mine later this morn to confirm.
Cheers Dave.
PostPosted: Sat Dec 26, 2020 9:39 am
Correct above as Dave said. I fitted a new one recently.
PostPosted: Sat Dec 26, 2020 9:44 am
Cheers guys much appreciated
Users browsing this forum: No registered users and 205 guests
