Rod change housing bush https://ausmini.com/forums/viewtopic.php?f=2&t=100634 |
Author: | Phil 850 [ Mon Dec 21, 2020 7:40 pm ] |
Post subject: | Rod change housing bush |
Below is a photo of the front bush in the rod change gear lever housing. As can be seen it as almost warn through the bush into the alloy housing. Can these be replaced and what with. Attachment: 2B7A96C6-18B5-463B-8622-0DAA4ED3333F.jpeg
Author: | wild_willy [ Tue Dec 22, 2020 6:15 am ] |
Post subject: | Re: Rod change housing bush |
I have sourced these bushes from bearing suppliers. |
Author: | hpal [ Wed Dec 23, 2020 6:29 am ] |
I have also machined a new brass bush and pressed it in with loctite, worked well. |
Author: | drmini in aust [ Wed Dec 23, 2020 7:14 am ] |
Phil drop it in to me, if I can't buy a bush I will machine one up. And fit it. |
Author: | Phil 850 [ Wed Jan 13, 2021 8:45 pm ] |
Picked up some bushes from CBC Bearings in Penrith today and pressed one into the housing. ![]() Here’s the details if anyone needs one in the future. Attachment: FD622AD9-CE63-4ECF-8120-322012CF0B49.jpeg
