https://ausmini.com/forums/
1275 Chamber issue
https://ausmini.com/forums/viewtopic.php?f=2&t=100621
Author:  Frog Johnson [ Thu Dec 17, 2020 8:24 pm ]
Post subject:  1275 Chamber issue
Hi everyone,
I picked up a head that had a gouge in the chamber, that ran slightly into the valve seat. It looked like an angle grinder or something had hit it.
I ground it down to get rid of it, but to a depth that left only a smidge of the original seat.
Could it be used if new seats were cut?
I know it would pose problems with rocker geometry etc, but I figured if I use shims under the rocker posts and Cooper S valves, maybe???
Author:  drmini in aust [ Thu Dec 17, 2020 8:48 pm ]
Post subject:  Re: 1275 Chamber issue
Just recut the seats. Or fit unleaded inserts.
Author:  Frog Johnson [ Thu Dec 17, 2020 9:29 pm ]
Thanks Doc, that’s good to hear. Do you think the rocker angles etc will be workable?
Author:  drmini in aust [ Fri Dec 18, 2020 4:12 pm ]
What is the casting number on the head, near the rocker posts?
Author:  Frog Johnson [ Fri Dec 18, 2020 4:20 pm ]
It’s a 12G940. (12938 or something near the thermostat)
Author:  drmini in aust [ Fri Dec 18, 2020 5:36 pm ]
OK. It's a Morris 1100S or 1300 auto head.
Just recut the seats, or get unleaded exhaust inserts fitted. Use standard 1100S valves or MK 2 S inlets if you prefer.
Shims are available to pack up the rockers if needed (usually not with a modified cam), also to pack up the springs to optimise assembled height.
