It is currently Sat Aug 23, 2025 10:31 am
PostPosted: Wed Dec 16, 2020 7:35 am
Hi all
Need some help nutting this out . I have a new build which has the following process completed : problem is , wet plugs no spark
-Non vacuum distributor aligned and static timed to 5 degrees via the test light method
- checked for 180 out by setting up TDC cyl 1 , cyl 4 on the rock.
-Diz points gapped to 12-15 thou
-coil resistance tested
- new plugs gapped
-power to coil confirmed
I have not checked plug spark as it’s just me . And I can’t crank and observe (engine in car)
I get wet plugs and absolutely no splutter . Not even a hint .
Could the diz have a bad module ?
Many thanks
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Wed Dec 16, 2020 11:17 am
The best way to do it on your own is to put a switch disconnect the small wire from the starter solenoid and wire a switch from the battery feed on the sol to the sol coil, the small terminal.
Then you can confirm whether spark is present at the variois places, coil, dizzy leads etc.
If the dissy has points then you will likely not have a module, if the points are firing an old style electronic ignition, then put back to standard electric for testing purposes.
The dissy orintation can be confusing. With the no 1 on compression (confirm by thumb over spark plug hole) make sure the rotor arm is pointing to the lead going to No1.
Please report back
Hope this helps
Cheers Dave.
PostPosted: Thu Dec 17, 2020 9:15 am
If by this you mean both rockers on No. 4 are rocking freely, that cylinder is on it's compression stroke - not No. 1.
You'll be 180 degrees out.
Rod.
______________________________
'63 Morris 850 (Old Secondhand CAR)
PostPosted: Thu Dec 17, 2020 2:58 pm
Maybe a bit of confusion over precise meaning of "cyl 4 on the rock"?
Does simonw mean that on cylinder 4, one valve is closing and the other opening.
Or does he mean that both valves on cylinder 4 are closed and the rocking is just the .015thou tappet clearance that is 'rocking'?
PostPosted: Fri Dec 18, 2020 4:07 pm
I have found that when the plugs get wet, they don't function. Something in the fuel stops the spark arcing across the gap...
PostPosted: Sat Dec 19, 2020 11:56 am
Ok so I am having another bash at this ...
Cyl 1 is on compression (finger test ) both rockers loose
Cyl 4is on exhaust stroke (exhaust rocker activated)
Rotor position is as photo
Now I’m going to check the spark at various positions...
The rotor doesn’t look like the correct position to
me .
Sent from my iPad using Tapatalk
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Sat Dec 19, 2020 12:24 pm
Sorry about the double posting ... (fixed by Mod)
Just measuring the coil again .. very hot and 4.7 ohms resistance across the LT terminals...
No spark at plugs .. so the hunt continues
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Sat Dec 19, 2020 2:20 pm
Testing lead resistance - all good . Each one was from 800 to 1100 ohms depending on length
Hooked it all up again and testing spark .
Only firing cyl 1.
2,3,4 no spark ....interesting.
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Sat Dec 19, 2020 2:38 pm
Simon, check the runout in the distributor lobe.
It’s sounding like you are losing spark when it is running.
With the plugs out - important bit this...rotating the motor by hand with a test light connected to the points side of the coil. In a full rotation you should see the light go on and off to match up with the rotor position for that cylinder. You should have 4 lightbulb moments.
Neil
PostPosted: Sun Dec 20, 2020 7:51 am
Looks like you have a preengaged starter, are you still getting sufficient voltage while cranking? I had put my lucas starter back in as it was only giving 8V while cranking
Sent from my SM-A520F using Tapatalk
PostPosted: Sun Dec 20, 2020 7:52 am
Only firing cyl 1.
The coil is hot because you are leaving the ignition on while testing / working. It will burn it out eventually, best to turn off when not actually testing spark.
The coil should measure @ 3 ohms LT when cold.
If you have a good blue white spark at No1 but not 2 3 4 then the points or rotor or cap or leads fault.
Process of elimination to fix.
Cheers Dave.
PostPosted: Sun Dec 20, 2020 1:54 pm
The rotor button could be the wrong one.... that gap looks huge
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Tue Dec 22, 2020 7:14 pm
simonw wrote:
The rotor button could be the wrong one.... that gap looks huge [/img]
might have something to do with it.............!
PostPosted: Wed Dec 23, 2020 7:53 pm
You could be onto something! :idea:
Cooper S Mk2
Cooper S Mk1
PostPosted: Thu Dec 24, 2020 6:06 pm
Well I got the right rotor finally ! And boom fired straight up ...
A welcomed noise after a full rebuild .
Can’t wipe the grin off my face ..... :)
Thanks for all your input guys
Simonw
Brisbane QLD
- 1969 Mini K
Users browsing this forum: No registered users and 270 guests
