Harley wrote:
if you have to ask if the car is safe to drive then you probably know it is not.
I definitely don't know that the car is unsafe, and nothing I've found indicates to me that it would be.
9YaTaH wrote:
If you are expecting me to say "go ahead" on a public forum the answer is NO.
I was actually expecting you to point out anything critical that I'd missed checking, or point out anything critical that I'd checked and hadn't planned on addressing.
simon k wrote:
but don't be surprised if there are more things worn out. If those parts are worn out there will almost definitely be more.
Yeah, that's exactly what I'm finding. It's hard to find the start and the end of each job. One minute I'm checking to see where the play is coming from in the steering, the next I've decided it's probably better value getting a disc brake conversion kit instead of overhauling the existing drum swivel hubs.
simon k wrote:
It's worth checking the top suspension arms and the radius arms at the back for play in the bushes/bearings. A pry bar or big screwdriver is all you need.
I'll check them out tomorrow when I install the tie rods and ball joints. I appreciate the help.
