Crown Wheel 64 Teeth AYG3069 https://ausmini.com/forums/viewtopic.php?f=2&t=100581 |
Author: | cooperess [ Sat Dec 05, 2020 11:50 am ] |
Post subject: | Crown Wheel 64 Teeth AYG3069 |
Any history on this part, there is nothing on google!! |
Author: | timmy201 [ Sat Dec 05, 2020 1:01 pm ] |
Post subject: | Re: Crown Wheel 64 Teeth AYG3069 |
You won’t really find Aussie part numbers on google |
Author: | winabbey [ Sat Dec 05, 2020 3:55 pm ] |
I'll check that part number tomorrow. Is it stamped on the part itself? |
Author: | cooperess [ Sat Dec 05, 2020 4:55 pm ] |
Attachment: Mini 64 Teeth Crown Wheel AYG3069 (1).JPG That is correct.
Author: | drmini in aust [ Sat Dec 05, 2020 6:15 pm ] |
At 64 teeth, Australian made, my bet would be Morris Mini Minor (850), Mini Deluxe or Mini K. (17/64T, 3.765:1) John Smidt would know... Edit Could also be Morris 1100. Or (maybe) Moke? 15/64T, 4.26:1 Edit 2 Measure the diameter accurately and I can confirm which ratio it's for. |
Author: | winabbey [ Tue Dec 08, 2020 3:41 pm ] |
I have the engineering drawing for this part which is a modified version of the UK crown wheel part #22A303. It was introduced into production in August 1964. I can't find any reference in Mini, Moke or Morris 1100 parts books, price lists or other technical documents to either the UK or Australian part number, which is very abnormal. It doesn't ring a bell with John Smidt either. So at the moment it's a mystery. |
Author: | cooperess [ Wed Dec 09, 2020 9:18 am ] |
Diameter is 165mm or 6.5". |
Author: | simon k [ Wed Dec 09, 2020 10:44 am ] |
that's a bit odd... might make a good door stop? |
Author: | cooperess [ Thu Dec 10, 2020 10:40 am ] |
"drmini" Any news for me! |
Author: | cooperess [ Mon Apr 12, 2021 10:27 am ] |
Could it be Austin 1800? |
Author: | drmini in aust [ Tue Apr 13, 2021 7:41 am ] |
cooperess wrote: "drmini" Any news for me! My 3.765 850 crown wheel measured 6.5", has 17/64 teeth. If it was out of a Morris 1100 15/64T it would be bigger diameter. |
Author: | Andosoft [ Tue Apr 13, 2021 9:17 am ] |
I have a Morris 1100 15/64 diff but can’t access right now, will be swapping out for 3.4 shortly so can check size and if it has a part # then (couple of weeks) |
Author: | Andosoft [ Sun May 09, 2021 10:55 am ] |
So the 15/64 crown wheel out of the morris 1100 gbox i have is a 22G370. So still not sure what you have is out of Attachment: 20210509_103755.jpg
Author: | Andosoft [ Sun May 09, 2021 11:13 am ] |
All of the crown wheels listed in Pub1011m all start with 22a or 22g, there isn't actually a 15/64. Perhaps they were a special order? You'd want pretty big wheels and ear muffs for anything over 80 |
Author: | drmini in aust [ Sun May 09, 2021 12:57 pm ] |
BMC used a 15/64 ratio in some products and 15/62 in others. With 12" (M1100) and 13" (Moke) wheels. Both fit a Mini box but yeah they're a bit short gearing. |
