https://ausmini.com/forums/
Rear window hinge
https://ausmini.com/forums/viewtopic.php?f=2&t=100577
Author:  Andosoft [ Fri Dec 04, 2020 11:52 am ]
Post subject:  Rear window hinge
There’s no gasket under the rear flapper window hinge, but should there be anything ? A dab of seam sealer to stop moister going in the screw holes ? Something to protect metal on paint ?
Same for the door striker plates (mk1). From memory there was some sort of goop under them but I cleaned them up long ago.
Author:  drmini in aust [ Fri Dec 04, 2020 1:39 pm ]
Post subject:  Re: Rear window hinge
I put a little Sikaflex under mine.
Author:  Bill B [ Fri Dec 04, 2020 2:17 pm ]
Ditto drmini - I use a thin bead of Silastic on both. The door striker plate needs to be positioned to get a level gap for the door alignment and easy closing but over time it moves and trying to avoid stripping the screws/threads holding it, some sort of adhesive seems to help stop movement.
