It is currently Mon Jun 30, 2025 7:41 pm
 Post subject: Rear window hinge
PostPosted: Fri Dec 04, 2020 11:52 am
There’s no gasket under the rear flapper window hinge, but should there be anything ? A dab of seam sealer to stop moister going in the screw holes ? Something to protect metal on paint ?
Same for the door striker plates (mk1). From memory there was some sort of goop under them but I cleaned them up long ago.
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
 Post subject: Re: Rear window hinge
PostPosted: Fri Dec 04, 2020 1:39 pm
I put a little Sikaflex under mine.
PostPosted: Fri Dec 04, 2020 2:17 pm
Ditto drmini - I use a thin bead of Silastic on both. The door striker plate needs to be positioned to get a level gap for the door alignment and easy closing but over time it moves and trying to avoid stripping the screws/threads holding it, some sort of adhesive seems to help stop movement.
Users browsing this forum: Barkfast and 83 guests
