Diff Crownwheel and Cage and output shaft bush clearances https://ausmini.com/forums/viewtopic.php?f=2&t=100546 |
Author: | captainwaldopepper [ Mon Nov 16, 2020 8:22 am ] |
Post subject: | Diff Crownwheel and Cage and output shaft bush clearances |
G'day all I can't seem to find this info anywhere in the manuals I'm replacing the bushes in my diff cage and crownwheel and am going to a machine shop to have them sized. What clearance is required (1 thou?). Also replacing the output shaft/sideplate bushes-what is the clearance required for these (1 thou?). Thanks Dave |
Author: | drmini in aust [ Mon Nov 16, 2020 12:39 pm ] |
Post subject: | Re: Diff Crownwheel and Cage and output shaft bush clearance |
I would give both the cage bushes 1 thou clearance. This is also what I give the diff side cover bushes when bored after fitting. Give the machine shop the pot joints or output flanges to measure. I find the diameter of new pot joints can vary by up to a thou depending on brand. If using old output flanges or yokes, if worn they can be machined down a few thou before boring the fitted bushes to suit. These bushes are 10 thou undersize approx. |
Author: | captainwaldopepper [ Mon Nov 16, 2020 6:07 pm ] |
Awesome-Thanks drmini ![]() |
Author: | Phil 850 [ Mon Nov 16, 2020 7:45 pm ] |
How did you get the bush out of the diff cage ? |
Author: | drmini in aust [ Mon Nov 16, 2020 7:58 pm ] |
Phil 850 wrote: How did you get the bush out of the diff cage ? I've not done one but if I did I would bore it out in the lathe, same as I've always done with primary gear bushes. |
Author: | captainwaldopepper [ Mon Nov 16, 2020 8:32 pm ] |
I left the old ones in the crown-wheel and cage and asked the machinist to bore them out and fit the new ones. I did manage to easily replace the output shaft bushes but I don't have the equipment at home to do any machining. |
