It is currently Wed Jul 02, 2025 1:19 pm
 Post subject: 1970 Mk2 Angle Brace
PostPosted: Thu Oct 29, 2020 9:28 pm
Hi, Can anybody please let me know the correct location for the front angle brace on a 1970 Mk2 S. I am replacing the front panel (It had an incorrect later fitted) and would like to put it in the right spot.
Thanks
Dave.
 Post subject: Re: 1970 Mk2 Angle Brace
PostPosted: Thu Oct 29, 2020 9:42 pm
As a starter have a look here - viewtopic.php?f=2&t=96171&p=1026729
PostPosted: Thu Oct 29, 2020 9:46 pm
Does this help, can measure if you wish?
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Fri Oct 30, 2020 9:37 am
When I visited Ron Williams little museum and workshop in Tenterfield in 2013. Didn’t know me from a bar of soap, but took the time to show me around. Wonderfull man, but I digress.
Took measurements for installation of the cross brace. 4” (100mm) from the inner panel at the lower and 8” (200mm) at the top. He even cut of a piece of the brace material he uses in resto’s.
PostPosted: Fri Nov 06, 2020 4:19 pm
Thank all for your help. I think I have it sorted.
Dave.
