It is currently Tue Jul 01, 2025 12:03 pm
PostPosted: Sun Nov 01, 2020 1:58 pm
The outer rubber belt seal that seals the window when it is up has come adrift
After looking at it, it appears previous owners gave up and glued it on but the glue has failed
I was going to glue it back on but the rubber strips have been butchered a bit where they fit into the clips
Firstly i am interested in buying new ones
Who sells the best ones
My car has 4 clips per side is that correct
And is there any secrets to fitting them
Thanks
Marc
1970 MK2 Cooper S
PostPosted: Sun Nov 01, 2020 2:14 pm
Fairly straight forward to fit with the flat S clips. I think it was this piece that needs to be trimmed to length.
I don't think you have much choice regarding quality as there's only one type available, to my knowledge.
https://minisport.com.au/mini-outer-doo ... mium-stock
PostPosted: Sun Nov 01, 2020 2:31 pm
never heard it called a belt seal before ?? easy job, bit of grease under the clips will save the paint
Allen
PostPosted: Sun Nov 01, 2020 4:21 pm
my ones look like rubbish compared to minisports ones
1970 MK2 Cooper S
PostPosted: Sun Nov 01, 2020 7:17 pm
they are common with MGB, you just need to cut them to length
PostPosted: Sun Nov 01, 2020 8:00 pm
Are you saying the MGB ones are better than the ones selling as Mini seals?
PostPosted: Sun Nov 01, 2020 8:07 pm
not better, they're probably made out of the same material in the same place... but pretty sure they were cheaper
PostPosted: Sun Nov 01, 2020 8:12 pm
Pretty sure the ones being sold at Mini spares places are the length to suit MGB, and need to be trimmed to suit Mini. The profile is the same.
PostPosted: Mon Nov 02, 2020 9:53 am
There is also a type that has the felty surface like a late model car. I used them on my latest build and the windows slide much better. I think I got them from classic motoring but would have to double check if you are interested. All types that I have used need to be cut to length
HYA2790 From Classic Motoring. Same part number as minisport but, as mentioned, it has a felty glass contact surface. With the rubber contact surface ones from minisport, I found that they would bind to the glass and wind inside out for at least the first 2 weeks until the rubber stiffens up and then they are ok.
1310 SC 1969 Morris Deluxe - 15psi boost
1293 1968 Morris Deluxe Miglia - 45 Weber
HSV Maloo Z Series - Comp Cam - 300rwkw
Ford DF LTD - 5Ltr
PostPosted: Mon Nov 02, 2020 11:14 am
That's interesting. Are you sure it's not the inner seal you are referring to? Classic Motoring describe HYA2790 as a rubber seal and in the description mention the inner felt seal (AHH6508). I would have thought a felt seal on the outside of the window would not be as good as rubber at keeping water out.
PostPosted: Mon Nov 02, 2020 11:18 am
Definitely not the inner. The felty material seems to seal just as good as the rubber. Its the same surface as you find on new cars. It is not like the felt on the inner, it is all rubber but the glass surface part is furry. I didn't realise they were like this until they arrived but was pleasantly surprised.
Sent from my SM-G950F using Tapatalk
Ford DF LTD - 5Ltr
PostPosted: Mon Nov 02, 2020 12:08 pm
OK, thanks. I wonder where they are sourced and why Classic Motoring have them and not other suppliers?
PostPosted: Mon Nov 02, 2020 1:09 pm
True,not sure
Ford DF LTD - 5Ltr
PostPosted: Mon Nov 02, 2020 1:35 pm
Suggest you phone the mini king - John Smidt, he has, over the last 6-8 weeks, supplied me with all the rubbers for my mk1 cooper s which includes f & r screens and filler,flipper windows, quarter glass seals,inner and outer side window seals, bailey channel.
They all fitted as they should even if they were hard to fit.
John has it all in stock and my biggest problem was the delivery delay with Australia Post despite their expensive watches.
Definitely worth a call or order on line if you have access to the part numbers as per pub1056
Ian
