What are correct dash globes? https://ausmini.com/forums/viewtopic.php?f=2&t=100478 |
Author: | phillb [ Sat Oct 24, 2020 12:55 pm ] |
Post subject: | What are correct dash globes? |
For an early mini central Speedo. I ordered new globes to replace some I my old dash globes. I noticed the old ones are marked 3w and are brighter than the 2.2w replacements. Then I couldn’t find any reference in the handbook or the Worksop manual to correct wattage. What we’re originally used? What is correct? Is there any issue using 3w bulbs? Sent from my iPad using Tapatalk |
Author: | OGW1152 [ Sat Oct 24, 2020 2:21 pm ] |
Post subject: | Re: What are correct dash globes? |
Hello Phillb, I have a Drivers Handbook that lists Panel and Warning lights BMC# BFS 987 2.2 Watts. Regards,Glen |
Author: | simon k [ Mon Oct 26, 2020 12:20 pm ] |
phillb wrote: Is there any issue using 3w bulbs? they'll be brighter, and draw a little more current and generate a little more heat. |
Author: | BBY755 [ Mon Oct 26, 2020 7:58 pm ] |
.....and dry out the wiring and plastic parts faster I imagine.... |
Author: | drmini in aust [ Mon Oct 26, 2020 8:58 pm ] |
I tried LEDs in mine, found they didn't output enough light sideways to illuminate the gauges properly. So I put new 2.2s in instead. |
Author: | phillb [ Tue Oct 27, 2020 4:59 am ] |
The 3w are just very slightly brighter so worth a try for the instruments. When I reconnected and tested the speedo I noticed the ign light seemed dim and thought something was wrong, then realized I was used to it having a 3w in there. I did find an old post here where it was recommended not to go any higher than 3w Would be interesting to see if i can feel a difference in the heat generated. Sent from my iPhone using Tapatalk |
