For the benefit of other punters, this black box used to be mine.
Sounds like you have both a faulty ignition module, and a fault in the black box.
When Chong's Accuspark black box failed it exhibited similar symptoms on the run back from Rylstone. So he bought a CB performance one.
If it won't fire without the black box in circuit, I reckon the ign module is toasted.
