HS4 Carb help https://ausmini.com/forums/viewtopic.php?f=2&t=100457 |
Author: | 850_Van [ Sun Oct 11, 2020 9:18 pm ] |
Post subject: | HS4 Carb help |
Hi all, I'm hoping someone may be able to help. I'm fitting a HS4 to my 850 and have hit an issue. Carb is a HS4 waxstat with carb spacer and it does not clear the bulkhead. I have a spare pre non waxstat HS4 that I was hoping to remove the jet and linkages and put them on the Waxstat carb. I know there are kits to convert, but was hoping this can be swapped. |
Author: | simon k [ Mon Oct 12, 2020 6:59 am ] |
Post subject: | Re: HS4 Carb help |
Yeah, you can swap parts around to make up what you want, it'll be fine |
Author: | 850_Van [ Mon Oct 12, 2020 7:52 am ] |
Thanks Simon. Just realised the spare I have is a RH and the waxstat is a LH so it may not work if the linkage is on the reverse side. I will play around with them today. |
