It is currently Tue Jul 01, 2025 9:32 am
 Post subject: Indicator stalk wiring
PostPosted: Sun Oct 11, 2020 4:17 pm
Hey mini nerds
I've finished wiring up my 1964 Morris mk 1 and have been pretty successful with everything although I'm not sure where the 5 wires go that come out of the indicator stalk. I can't locate it on my wiring diagram and was wondering if you guys had any tips. I've got a green/white, green/yellow, green, brown/black, green/red.
I assume some go to the flasher unit but I'm not sure as to which ones. Any help is hugely appreciated
PostPosted: Sun Oct 11, 2020 7:13 pm
I literally just rewired mine today.
Brown with black trace was the horn wire (goes to ground when horn is pressed).
Green with white trace is left hand indicator.
Green with red trace is right hand indicator.
Green with black trace is power (that power will get fed through the green+tracer wires when you indicate in the relevant direction)
EDIT - I see yours doesn't have green plus black. I suspect it might be your green +yellow. If I were you I would check continuity of this wire and the two indicator wires above. There should be no continuity when blinker is not selected. There should be continuity between this wire and the appropriate green + tracer wire depending on whether you select turn left or turn right on the stalk. That will set you right.
I believe the straight green MIGHT be for the little blinky light on the end of the stalk but I am not using it so another could confirm)
You could double check this with the wiring diagram. Also they should have accompanying wires of the same colours on the loom, so should just join like plus like? (Although on my loom the brown with black trace wire goes to a purple with black trace wire).
EDIT 2 - you will need to run the flasher unit too, not just run power to the stalk then out to the blinkers. I can't be 100% on that part, but I believe it goes: power (green usually) to the "X" labelled connector of the flasher, then flashing power out the "L" labelled connector of the flasher (via a green wire with orange tracer in my case) to end up at the indicator stalk where (in my case) the colour is green with black tracer.
The "P" on the flasher unit goes to the single green indicator lamp on the speedo (via green plus purple in the pic below), or you can send it to the indicator stalk lamp if you have one. I don't use this wire as I have orange Left and Right lamps on the speedo, so they are wired in to the green + red, and green + white wires.
Here's the pic of the back of the socket for the flasher unit if that helps.
Sent from my Pixel 3 XL using Tapatalk
PostPosted: Mon Oct 12, 2020 10:07 am
You are my hero.
Thanks so much for the help. I'll try and rewire it this weekend and tell you how it goes.
Thank you so much again
PostPosted: Tue Oct 13, 2020 1:55 pm
Glad I could help :) good luck
