Large grommet below central Speedo https://ausmini.com/forums/viewtopic.php?f=2&t=100448 |
Author: | phillb [ Fri Oct 09, 2020 7:44 am ] |
Post subject: | Large grommet below central Speedo |
Mine needs replacing but can’t find one anywhere either here or UK? It the one that protects the harness as it passes thru the dash parcel shelf to below. Anyone have a spare they are willing to part with? Sent from my iPad using Tapatalk |
Author: | TDS76 [ Fri Oct 09, 2020 10:21 am ] |
Post subject: | Re: Large grommet below central Speedo |
I had some of this info ready to hand as I need one as well: Part No. 3H1457 Quick Google showed this link: https://www.mgsales.com.au/products/3h1457 That has the size as 1 3/8 x 3/4 and $3.51 I have used Clarkes Rubber as a good source for grommets and they have that size (35x19mm) for $2.55 |
Author: | cooperess [ Fri Oct 09, 2020 12:47 pm ] |
Attachment: 3H1457 Mini Grommet (3).JPG Attachment: 3H1457 Mini Grommet (1).JPG This is the grommet I have and willing to part with.
Author: | phillb [ Fri Oct 09, 2020 2:26 pm ] |
Thanks for the replies. Someone local to me has offered one, but I’ll keep the other offers and info in mind. Thanks. Sent from my iPhone using Tapatalk |
Author: | Convertible Mini [ Sat Oct 10, 2020 8:14 am ] |
If stuck you can also use a piece of 10 mm split convoluted tubing and slide it around the edge. it will give good enough protection too. |
