Light dip switch https://ausmini.com/forums/viewtopic.php?f=2&t=100412 |
Author: | Morbo28 [ Thu Sep 24, 2020 8:23 pm ] |
Post subject: | Light dip switch |
Hey everyone. I'm elbow deep in a wiring loom. The dip switch for the headlights - in 1967/8 my understanding is that the floor mounted dip switch selects between low beam OR high beam. Or am I mistaken, does the dip switch turn on high beam AND keep the low beam on? Thanks! (Just double checking wire amperage requirements) Sent from my Pixel 3 XL using Tapatalk |
Author: | gtogreen1969 [ Thu Sep 24, 2020 8:31 pm ] |
Post subject: | Re: Light dip switch |
The dipper switch only swaps from Low Beam circuit to High Beam circuit (and High Beam Dash Light) |
Author: | Morbo28 [ Thu Sep 24, 2020 8:35 pm ] |
Okay great, so it is either/or, not both. Thanks! Sent from my Pixel 3 XL using Tapatalk |
Author: | gtogreen1969 [ Thu Sep 24, 2020 8:45 pm ] |
Morbo28 wrote: Okay great, so it is either/or, not both. Thanks! Sent from my Pixel 3 XL using Tapatalk Correct - Only one at a time. Here is a diagram. U (Blue) is power from switch UR (Blue/Red) is Low Beam UW (Blue/White) is High Beam Attachment: Picture1.jpg
Author: | Morbo28 [ Thu Sep 24, 2020 8:48 pm ] |
Thanks mate. I'm powering low beam and high beam relays from the same power cable, which will be fine given only one will be on at a time. Sent from my Pixel 3 XL using Tapatalk |
Author: | Barney Rubble [ Thu Sep 24, 2020 9:05 pm ] |
if you have an issue with one side would you not lose both hi and low probably better to have seperate power to 30 |
Author: | Morbo28 [ Thu Sep 24, 2020 9:15 pm ] |
Good question. I'm doing a short run of a power cable to the relay block which is shared. Then separate everything from then on, including separate relays with built in fuses. So if low beam circuit blows a fuse, the high beam circuit it still active. If there is an issue further up the line, something bad has happened and I have bigger fish to fry ![]() (If I add another power cable to the relay block I have to go to larger Deutsch connector, which I'd like to avoid). Sent from my Pixel 3 XL using Tapatalk |
