Rod change selector shaft https://ausmini.com/forums/viewtopic.php?f=2&t=100370 |
Author: | Phil 850 [ Tue Sep 08, 2020 4:50 pm ] |
Post subject: | Rod change selector shaft |
The “tab” fell out of the selector shaft. It’s usually pressed in I think. Can I just weld the tail of it to the shaft and grind off any excess weld ? Attachment: F175818D-E2F5-43CD-A63C-60BB3212514F.jpeg
Author: | drmini in aust [ Tue Sep 08, 2020 6:30 pm ] |
Post subject: | Re: Rod change selector shaft |
(puts welding engineer hat on) I would shorten it a bit so it's a couple of mm below the surface to plug weld it. It's an unknown alloy steel, so I would stick weld with a 309 or 316 rod, or MIG it with S6 wire. |
