https://ausmini.com/forums/
Su jetting
https://ausmini.com/forums/viewtopic.php?f=2&t=100354
Author:  Dan69s [ Fri Sep 04, 2020 8:31 pm ]
Post subject:  Su jetting
Hi all,
I have a mk1 Cooper s motor. It has been bored to 1330 with Russell Engineering pistons, and standard Cooper s crank, has a RE266 cam. The head is ported and polished aNd I’m running twin 1/12 inch su’s.
My question is, what is the set up you would use to tune the su’s, and which plugs you would use.
Thanks in advance.
Daniel
Author:  simon k [ Fri Sep 04, 2020 8:36 pm ]
Post subject:  Re: Su jetting
#6 needles were good when I had a similar spec
Author:  Dan69s [ Sun Sep 06, 2020 4:21 pm ]
Thanks
Author:  Ian_B [ Sun Sep 06, 2020 5:07 pm ]
Number 7 same at idle and off idle but it is a but a bit richer every where else .Even CP4 didnt work for me
Author:  Dan69s [ Mon Sep 07, 2020 4:22 pm ]
the trouble im having is it idles fine, but really rich at higher revs.
Author:  timmy201 [ Mon Sep 07, 2020 5:26 pm ]
So what needle and spring do you have now?
Author:  drmini in aust [ Thu Sep 10, 2020 7:12 am ]
I ran #6 needles in the 1293 with Ramflo filters.
A/F meter on the dyno drew a straight line.
It ran a Wade cam and 1.44 Corolla rockers.
Author:  diecast [ Thu Sep 10, 2020 5:44 pm ]
NGKBP6ES plugs for casual road driving, BP7ES plugs for being driven hard
