998 valve brand options https://ausmini.com/forums/viewtopic.php?f=2&t=100270 |
Author: | Morbo28 [ Fri Aug 07, 2020 11:00 pm ] |
Post subject: | 998 valve brand options |
Hi everyone, In my NA 998 I think I'm going to run a 1.156" inlet and 1.062" exhaust. (If it helps, I'm thinking ~10:1 CR with flat tops, about +0.040, I'm running std rockers and a road cam (RE13/266/276 type of range) and std pressure double valve springs. Conservative home throat porting job and valve de-shrouding of head as per GR/Vizard ) Just after advice on good options for valves. I see GR does an exhaust valve of the size I've mentioned. From his website I can't see if he does the inlet size I'm after? I am just trying to decide which I should choose such as: * standard part number valves of my chosen sizes vs other manufactures eg GR or another manufacturer * collet types - is it okay to mix ex vs in collet types? * stem lengths or thicknesses * (or ideas on whether you think my valve sizes I've chosen are appropriate...) Cheers |
Author: | Morbo28 [ Fri Aug 07, 2020 11:17 pm ] |
Post subject: | Re: 998 valve brand options |
Eg if looking at std type valves, would i be better with ![]() or ![]() ? |
Author: | drmini in aust [ Sat Aug 08, 2020 6:35 am ] |
I did an 1100 head for a mate's 68mm bore 1108, I used 1.219" 998 Cooper inlets and 27mm exhausts. GR profiled the valve seats and I did a little porting. You can mix collet types ok but keep valve lengths the same. I used 7000rpm valve springs from Karcraft. Cam is GR's 266SS. Edit You could use a 998 head but there's a lot more metal to remove. |
Author: | Morbo28 [ Sat Aug 08, 2020 10:11 am ] |
drmini in aust wrote: I did an 1100 head for a mate's 68mm bore 1108, I used 1.219" 998 Cooper inlets and 27mm exhausts. GR profiled the valve seats and I did a little porting. Thanks Doc. I thought the 1.219" inlet might be too big for my purposes, but do you think that's a good option for me given the specs I'm looking at?You can mix collet types ok but keep valve lengths the same. I used 7000rpm valve springs from Karcraft. Cam is GR's 266SS. Edit You could use a 998 head but there's a lot more metal to remove. Sent from my Pixel 3 XL using Tapatalk |
Author: | drmini in aust [ Sun Aug 09, 2020 5:22 am ] |
Definitely. |
Author: | kiwiinwgtn [ Fri Sep 18, 2020 7:43 am ] |
Morbo28 wrote: Eg if looking at std type valves, would i be better with ![]() or ![]() ? What springs are you planning on using, I was thinking of turning down some 1300 valves to cooper sizes and using 1300 springs as I have so a good supply of 1300 valves and a lathe. would this work okay |
Author: | drmini in aust [ Fri Sep 18, 2020 7:49 am ] |
Hi Bernard, If using 1300 valves you need 2mm shims under the rockers, and 3mm under the 998 double springs. 12mm flat washers work here. Because 1275/1300 valves are about 2mm longer. I have a ported 295 head here with 1300 (Morris 1100S) standard valves. I will SMS you a pic. Edit I would use stock 1300 inlets and turn the exhausts down to 27mm. |
Author: | kiwiinwgtn [ Fri Sep 18, 2020 8:24 am ] |
drmini in aust wrote: If using 1300 valves you need 2mm shims under the rockers, and 3mm under the 998 double springs. 12mm flat washers work here. Because 1275/1300 valves are about 2mm longer. Hi Kev can I use 1300 valves to match the valves, I always check seat pressures and rocker geometry |
Author: | drmini in aust [ Fri Sep 18, 2020 8:26 am ] |
You mean springs? Yes if you check pressures and install height. |
