https://ausmini.com/forums/
Minisprint body cuts
https://ausmini.com/forums/viewtopic.php?f=2&t=100240
Author:  748rum [ Fri Jul 31, 2020 8:40 pm ]
Post subject:  Minisprint body cuts
I have a ‘63 Mini 850 body that needs a metric shedload of work. It’s missing the floor, centre tunnel etc. and needs some work around the pillars on the LHS. If it wasn’t for the matching numbers engine/box, good subframes and other stuff I would probably just sell it to someone to use for body cuts.
With the work that I will have to do to restore it, especially around the B&C pillars and inserting new floor/sills/tunnel, I’m thinking it’s a good opportunity to do something like a Minisprint. Whilst I would love to get Mr Trickett to work his magic I don’t have the money to ship it off to France.
I have chopped and channeled old Fords and Chevs in the distant past building hotrods and also have some skilled friends who still do that stuff every now and again so there won’t be a shortage of people to play with angle grinders and MIG welders.
The bit that is missing is rough cut lines, particularly around the front of the car. I would be looking at 2” out of the body and 2” out of the pillars. I think I’m ok with the cuts from the A pillar back but can’t find much info on how to slice and dice the front including firewall and inner panels.
I’m not in a rush to build and probably won’t be able to start on it until next winter once I have finished my survivor ‘63 850 and installed the V8 in my MGB so will have plenty of time to measure and measure and plan and measure before I cut.
Does anyone have any info they can share on this?
Looking at going from this:
To this:
Author:  gtogreen1969 [ Fri Jul 31, 2020 8:56 pm ]
Post subject:  Re: Minisprint body cuts
Monaco may be able to assist - viewtopic.php?f=3&t=96822
Also check out his Minisprint FB page - https://www.facebook.com/groups/1189007311209214/
Author:  748rum [ Fri Jul 31, 2020 9:00 pm ]
Thanks for that. I’m on a couple of the Minisprint forums but hadn’t come across that one yet so will have a look.
Author:  Scoop [ Fri Jul 31, 2020 11:02 pm ]
http://www.theminiforum.co.uk/forums/to ... ini+sprint
Try this link, it may help.
Author:  748rum [ Sat Aug 01, 2020 1:23 am ]
Thanks, that helps a bit with my understanding. Still struggling with the firewall but there was some info on the Facebook group that I think I can use.
Author:  9YaTaH [ Sat Aug 01, 2020 9:39 am ]
748rum wrote:
I have a ‘63 Mini 850 body...
Hope your body is under 165cm :idea: :D
Author:  748rum [ Sat Aug 01, 2020 10:16 am ]
Unfortunately not but that’s just another interesting problem to work through.
I have seen a couple of builds where they have replaced the cross brace with different bracing to lower the seat pretty much to the floor so was thinking of that as an option. Seeing as I have to build up a new floor/sills/tunnel/cross-brace it’s something I was thinking about to solve that issue. After chatting to the engineer I have used for other stuff he doesn’t think there will be much more involved above that required to get the cuts approved but he is going away to do some research and let me know.
