It is currently Sun Jul 06, 2025 5:36 am
PostPosted: Thu Jul 23, 2020 9:08 pm
Hi all,
I've had a stab at pulling the rear end apart today. While most of it is apart I'm thinking its probably a smart idea to replace the trunnion bushes.
What are the pros and cons of rubber vs poly bushes pls.
Keen to hear experiences with both.
Sent from my SM-G960F using Tapatalk
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
PostPosted: Fri Jul 24, 2020 5:53 am
Rubber has lasted on mine 50 years. The jury is out on poly.
PostPosted: Fri Jul 24, 2020 10:01 am
New rubber ones were cracked and perished on my car in less than six months. I'd go poly or even Swiftune alloy next time to be honest.
PostPosted: Fri Jul 24, 2020 10:32 am
Are we talking about rear sub frame bushes x 8 = 2A5818?
PostPosted: Fri Jul 24, 2020 6:27 pm
Poly bushes in mine fell to pieces in my fingers changed for rubber all good .
PostPosted: Fri Jul 24, 2020 9:24 pm
It comes down to quality of either. Crap crap crappy versions of rubber AND poly out there. Spin the wheel and see what you get lol.
I preferred Poly as I was restoring mine, but if I had my time again and IF I could guarantee good quality rubber, I'd go rubber in most instances these days I think (except the rubber/poly combo on the front tie rod).
Sent from my Pixel 3 XL using Tapatalk
PostPosted: Sat Jul 25, 2020 9:03 am
Wherever possible I go for rubber. Fitting bushes to cars every day and rubber is always the first choice for road use. Make sure you use a proper rubber grease on assembly.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
Users browsing this forum: No registered users and 116 guests
