It is currently Mon Jul 07, 2025 3:28 pm
 Post subject: Head Gasket
PostPosted: Tue Jul 21, 2020 6:45 pm
I am back into minis,I now have a 1967 deluxe.
Today I replaced the head gasket (composite type) and I noticed a slight water leak at each end of the head.
The leak stopped after the engine warmed up.I did not use any sealant on the gasket.
Question is should I re torque the head again tomorrow.The gasket set I used was HYL3610 from minisport.
Thanks all.
1967 Morris mini Deluxe
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
1982 Jaguar XJ6 series 3
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
 Post subject: Re: Head Gasket
PostPosted: Thu Jul 23, 2020 1:49 pm
Yes, definitely retension the head and reset valve clearances. Do this with a cold engine.
PostPosted: Thu Jul 23, 2020 9:30 pm
Hi, sorry Stibbsy, but I do beg to differ on cold head.
Retension a cast iron head hot , and an alloy head cold
To retension, release pressure in the cooling system ( could be under pressure as is hot ..caution)
tension bolts in the order recommended in the workshop manual, or starting in the centre work your way evenly outwards
Undo the bolt you are tensioning by at least half a turn, and then bring it up to the required torque in one movement
If you just tension a bolt without undoing , you will just get the breakaway torque, and thats not enough
reset tappet clearances when finished .... easiest way to do that is subtract the number of the valve down (open) from 9 , then adjust that one
Dry threads on bolts also generally read high so lube them
Cheers Lindsay Siebler
1959 Austin A40 Farina fun car
1965 Mk1 Cooper S restored
1970 Colt 1100F SS restored
2014 Mitsubishi Imiev fully electric daily driver
1948 Allard M coupe Olds 215 v8 project
1971 Twin cam Escort ex Uk championship winning rally car project
PostPosted: Fri Jul 24, 2020 5:36 am
All done,no leaks.
Thanks Guys
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
Users browsing this forum: BBY755 and 84 guests
