https://ausmini.com/forums/
Diff planet gear washers
https://ausmini.com/forums/viewtopic.php?f=2&t=100213
Author:  Phil 850 [ Tue Jul 21, 2020 8:17 pm ]
Post subject:  Diff planet gear washers
Can I grind “slots” in the diff housing and fit the later planet gear washers with ears into the slots to ensure the washers don’t rotate.
Phil
Author:  timmy201 [ Tue Jul 21, 2020 8:19 pm ]
Post subject:  Re: Diff planet gear washers
Yes you can. Mine has been done like that
Author:  Scoop [ Tue Jul 21, 2020 8:55 pm ]
It's a very good idea to do that, it will protect the diff housing against future wear.
Author:  Phil 850 [ Wed Jul 22, 2020 7:53 pm ]
Thanks guys, I presume you just grind enough to let the washer sit on it’s seat and hold the tab from rotating ?
Has anyone got a photo of the modification or of a A+ diff housing?
Author:  simon k [ Wed Jul 22, 2020 8:09 pm ]
I think I used a square sided file... it's very soft metal
Author:  lomin [ Wed Jul 22, 2020 9:36 pm ]
Hi, the A plus system is far superior, but choose a diff housing that has not had the old thrust washers eat into and make it wider ,if possible . Another bonus while you are at the carrier is to replace the output bush in the diff carrier and the same one in the crownwheel. They are usually very worn, and fitting a new bush (ata7378 ?) and then machining it to fit your output shafts makes the gearbox driveline so much nicer...I never do a gearbox without doing this cheers Lindsay Siebler and then there is the diff side cover bushes ...and ...and
Author:  Phil 850 [ Thu Jul 23, 2020 8:58 pm ]
The diff I pulled out of the gearbox was worn on one planet bearing, fortunately I have a second one that is not worn on either planet bearing.
I have a new crown wheel with bearing and pinion (3.1:2) and I will check and replace the other bearings.
Phil
Author:  iansmini67 [ Mon Jul 27, 2020 1:46 pm ]
This is how mine turned out
Sent from my SM-G965F using Tapatalk
Author:  Phil 850 [ Mon Jul 27, 2020 9:43 pm ]
That looks simple enough to do :D
Phil
Author:  Andosoft [ Mon Mar 15, 2021 1:54 pm ]
Does anyone have a pic of where they have filed the housing to fit the thrust washer ears? The pics above don't show for me
Author:  timmy201 [ Mon Mar 15, 2021 4:00 pm ]
Found these on google. This would be the A+ type but the concept is the same
Author:  cooperess [ Mon Mar 15, 2021 8:24 pm ]
This is an original diff I filed.
