Hi, sorry Stibbsy, but I do beg to differ on cold head. Retension a cast iron head hot , and an alloy head cold
To retension, release pressure in the cooling system ( could be under pressure as is hot ..caution) tension bolts in the order recommended in the workshop manual, or starting in the centre work your way evenly outwards Undo the bolt you are tensioning by at least half a turn, and then bring it up to the required torque in one movement If you just tension a bolt without undoing , you will just get the breakaway torque, and thats not enough reset tappet clearances when finished .... easiest way to do that is subtract the number of the valve down (open) from 9 , then adjust that one Dry threads on bolts also generally read high so lube them Cheers Lindsay Siebler
_________________ 1959 Austin A40 Farina fun car 1965 Mk1 Cooper S restored 1970 Colt 1100F SS restored 2014 Mitsubishi Imiev fully electric daily driver 1948 Allard M coupe Olds 215 v8 project 1971 Twin cam Escort ex Uk championship winning rally car project
