It is currently Sat Jul 05, 2025 12:26 am
 Post subject: Valve Stem Seal
PostPosted: Fri Jun 26, 2020 3:40 pm
Hi All,
I am cleaning up a 202 head and when I remove the valve spring there is this o-ring thing that prevents the valve coming out.
What is this?
Where can I get replacements for this? I can't find any mention of them at any of the usual online places (unless I'm mistaken for what it is).
Thanks
 Post subject: Re: Valve Stem Seal
PostPosted: Fri Jun 26, 2020 3:51 pm
Looks like an old rubber valve stem oil seal.
PostPosted: Fri Jun 26, 2020 4:18 pm
I’d just replace them with modern valve stem seals, they actually work :)
PostPosted: Fri Jun 26, 2020 4:27 pm
They are included in head gasket sets. Used only with the wide collet groove valves. 850-997-998-1098.
As said above 1275 valve seals can be fitted, but the original valve guides don't have a retaining groove for them. Use some Loctite on the guide.
PostPosted: Fri Jun 26, 2020 4:32 pm
ok, so replace them with: https://minikingdomonline.com.au/produc ... er-s-type/ ?
And then which Loctite? Just the low strength (222) ?
Thanks
PostPosted: Fri Jun 26, 2020 4:47 pm
Thanks
222 is fine. I have 262 and used that. Even 515 or permatex anaerobic gasket maker will work.
