https://ausmini.com/forums/
Fuel tank pickup removal
https://ausmini.com/forums/viewtopic.php?f=2&t=100124
Author:  simonw [ Wed Jun 24, 2020 11:38 am ]
Post subject:  Fuel tank pickup removal
I am about to refurbish the interior of the fuel tank and wonder how to protect the pickup mesh if i choose to coat the inside..
I know others have put the coating in there , so looking for some guidance on how to not block the pickup pipe.
The tank may or may not need the coating ... so i suppose i should do a fill/leak test now while its out ....
Anywho
Author:  simon k [ Wed Jun 24, 2020 9:33 pm ]
Post subject:  Re: Fuel tank pickup removal
Dr Mini always says to poke something up the outlet pipe to remove the mesh completely and run a proper modern fuel filter underneath the tank...
Author:  drmini in aust [ Thu Jun 25, 2020 5:55 am ]
If you do this make it a decent sized filter so restriction doesn't starve the pump.
I have used Falcon or Holden metal case ones before.
Don't use Purolator etc glass case filters under there they can get broken.
Author:  simonw [ Thu Jun 25, 2020 8:20 pm ]
Legends . Thank you Dr mini and simonk
Author:  simon k [ Fri Jun 26, 2020 10:43 am ]
I was under my car last night - I just have a basic straight through plastic filter, nothing special - about 1.5" diameter and maybe 2.5" long. Even when I was running supercharger/injection with 100bhp@atw I used a pretty normal type of filter before the fuel pump
