It is currently Fri Jul 04, 2025 3:16 am
 Post subject: Caliper rebuild
PostPosted: Tue Jun 23, 2020 11:53 am
I've finally started work on my Mini.
Everything will be stripped and inspected to see what can be refurbished and what needs replacing.
The Disk calipers will come up OK surprisingly but I wont be using them for some time and am wondering what to use on the bores to stop rust forming in the interim.
Does anyone know what's used on new parts?
Ken
Restoring Mk1 Cooper S
I spend most of my money on cars and Whiskey. The rest I just waste.
 Post subject: Re: Caliper rebuild
PostPosted: Tue Jun 23, 2020 12:26 pm
With brake parts I use rubber grease over all surfaces, assemble them and store as a complete unit. Rubber grease is used for assembling brake parts and acts as a preservative while in storage.
PostPosted: Tue Jun 23, 2020 1:23 pm
I agree with above.
If you are going to spray paint them I would leave until finally assembled and pistons pushed in.
PostPosted: Tue Jun 23, 2020 3:07 pm
Thanks for the replies. I'll pick some rubber grease up on the way home.
