G'day,
Thinking about what I need in the way of door mirrors, or if I need them at all?
My 1963 850 was fitted with one Wibroc on the drivers door. Nothing on the passenger side. The old Wibroc has seen much better days so I'm looking for a good alternative. I've welded up the old holes in the door ready for painting so I can either leave them off or fit whatever is best.
First question is do I really need to have them (not legally but for actually using them to see what's behind / at the side?). I haven't driven a Mini yet so all new to me. I've read older threads on here about mirrors and it seems that the internal rear view mirror vibrates at speed and is pretty much useless.
Next, do I need one at all on the passenger side? Lots of cars seem to have only the drivers side one. Cosmetically, one each side might look better.
If I was fitting mirrors, I'd narrowed my choices down to either the Bullet or Tex ones as per the links below:
https://minisport.com.au/right-hand-bul ... r-arm-typehttps://minisport.com.au/mini-door-mirr ... -steel-rahI've read here that some of the older versions of these had dodgy plastic mounting brackets and tended to fall off. Is that still the case or are the newer ones OK? I've also read that the Bullet type are pretty much for cosmetic purposes and not much good as a mirror.
Any suggestions on good quality ones welcome.
Thanks, Rocky
